Hello Guest it is November 22, 2026, 02:28:45 PM
Author Topic: 0.5mm off in cuts and pockets are creating slopes at one side  (Read 6814 times)
hello, I'm using mach 3 breakout board with TB6600 stepper controllers and i use fusion 360 to build my models
all the cuts i make they are losing 0.5mm like if i cut a 15x15mm square it will be 14.5x14.5mm and if i make a pocket it is creating a weird slope at one side
check in the attachments and same way losing 0.5mm
i have pretty much checked everything on the machine and software but cannot fix this issue
