Hello Guest it is November 15, 2026, 06:24:02 PM
Author Topic: Mach 3 with usb controler  (Read 31592 times)
« on: May 10, 2019, 01:30:16 AM »
Good morning
(I'm a newbie)
I know this is not a forum for chinese cnc's. I just can not find help anywhere.
I'm using cheap 3040 cnc router. The usb controler is bl-usbmach v2.0 d1712 . The controller has a probe for z auto tool zero wich I cannot get to work.
I have done the following:
Traced the wires to the controller
Check the voltages (5v) on the point where wires terminate
When touched together the input on the board change.
I have programened the macro
Set the probe setting to active on inputs
I presume being Usb controller no lights on diagnostic screen lights up at all so I cannot see if the program see the correct pin for probe.
This happens:
When the outo zero button is clicked the z axis moves but does not react to the contact on the probe.(does not stop)
Is there any way that I can detect where my usb probe pin go into the Mach3 software.
Any help will be apreciated
Regards
Cobus
What else can I do
Offline TPS
  •  2,627 2,627
Re: Mach 3 with usb controler
« Reply #1 on: May 10, 2019, 01:42:08 AM »
can you post a Picture of the Controller and the wiring of the probe Input?
« Reply #2 on: May 10, 2019, 01:53:14 AM »
I can not down load photos from cell phone no data cable. The picture is of the controller i use.
The probe are connected to gnd and positive on IN2
Hope this help
Cobus
« Reply #3 on: May 10, 2019, 02:06:39 AM »
This shows the wiring
Offline TPS
  •  2,627 2,627
« Reply #4 on: May 10, 2019, 02:38:31 AM »
have you set in Config -> Ports&Pins -> Input Signals
Probe enabled port 1 pin 11 active low enabled ?
« Reply #5 on: May 10, 2019, 02:41:40 AM »
Working WOW
Please tel me how you found this out PLEASE
Regards
Cobus
Offline TPS
  •  2,627 2,627
« Reply #6 on: May 10, 2019, 02:48:11 AM »
found some Kind of instruction here:
https://de.aliexpress.com/item/MACH3-USB-interface-board-instruction-BL-UsbMach-V2-0/32821140872.html
if you scoll down you will find Input/Output settings
« Reply #7 on: May 10, 2019, 02:55:43 AM »
Tps
THANK YOU. I aslso see my estop config as well wich is not working
I don''t know how to thank you . I was searching the net and been on this for a week of wichI worked proximitly 2 full days on it.
Regards
Cobus
