Hello Guest it is November 23, 2026, 01:04:10 PM
Author Topic: Parallel port issue  (Read 19833 times)
  •  9,378 9,378
Re: Parallel port issue
« Reply #10 on: May 10, 2019, 05:17:29 AM »
Reuelt has made a good point - you need to enable the Charge Pump (Config / Ports & Pins / Outputs) if you have your G540 Charge Pump turned on.
« Last Edit: May 10, 2019, 05:21:03 AM by Tweakie.CNC »
« Reply #11 on: May 13, 2019, 05:06:28 PM »
ISSUE SOLVED
I have solved the Mach 3 issue having checked the pin voltages and determined the dual printer card I have used for several years was faulty as was one other and also a new express card was only 3.3 volts.
I located an old XP computer with a on board parallel port and all works normally.
I thank all the contributors who helped to solve the issue.  Thank you.
  •  9,378 9,378
« Reply #12 on: May 14, 2019, 12:15:41 AM »
Excellent.  ;)
