Hello Guest it is November 13, 2026, 12:57:36 PM
Author Topic: mach 3 and win xp pro  (Read 7713 times)
« on: May 06, 2019, 06:11:22 AM »
i have just load mach3 into my pc running windows xp pro and i can not get it run propery i have the correct settings as i used in my last pc but this one is not doing so. when i load my gcode it is cutting the parts like the where 1/4 the size i can't fathom this out i have been using same cnc machine the units are set to mm and the software i use is cut2d and that is set to mm the only thing that i have noticed that i have not notice before in device manager i see mach3 pulsing engine i have never seen that before??
Offline TPS
  •  2,627 2,627
Re: mach 3 and win xp pro
« Reply #1 on: May 06, 2019, 08:34:07 AM »
Jogging is ok?
if so try some simple GCodes via MDI Input line
Zero your x axis
G1X100F200 will drive x axis to 100 (check the distance)
G1X0F200 will return to Zero (check as it is on the original startpoint)
repeat a couple of times.
