Hello Guest it is November 13, 2026, 01:17:24 PM
Author Topic: Program crash  (Read 8832 times)
Program crash
« on: May 02, 2019, 01:19:27 PM »
Running XP stand alone version R3.043.066 everything has gone haywire and status window says cannot reverse run from present feedhold
Can any member give me a clue
Offline reuelt
  •  520 520
Re: Program crash
« Reply #1 on: May 03, 2019, 01:44:02 AM »
Open up the computer case and blow out all the accumulated dust esp from the CPU heatsink and PSU (power supply)
If it is still not stable then:-
Backup your profiles and license etc and downgrade the MACH3 to the patched version R3.043.062
It is the version that is currently on NFS website and labeled only as Mach3Version3.043.exe
"the gift of God is eternal life through Jesus Christ our Lord"
Re: Program crash
« Reply #2 on: May 03, 2019, 01:52:54 PM »
Thank you, Reuelt,
 Yesterday I managed to get the program back after the crash I think the problem was that the Feed adjustment was somehow locked and reading 1% and when trying to reset to 100% it was not responding it would go up to 80% and then drop back to 1%,
Appreciate your suggestion and will certainly do that,
Thanking you, Edmund........Alberta
