Hello Guest it is November 23, 2026, 02:42:23 PM
Author Topic: EdytorNC support for MACH3 in NEXT release?  (Read 8483 times)
Offline reuelt
  •  520 520
« on: April 30, 2019, 05:47:44 PM »
FYI
I edited the CNC-tips.txt file to include 100% of G and M codes for MACH3.
Unfortunately EdytorNC had been hard-coded to only support
[OKUMA]
[FANUC]
[SINUMERIK]
[SINUMERIK_840]
[HEIDENHAIN]
[HEIDENHAIN_ISO]
[LinuxCNC]
I sent my entries to author EdytorNC of Artur Koziol who then said he will include MACH3 tips in the global tooltips list of the NEXT RELEASE of EdytorNC.
In the meantime, I have put MACH3 G & M codes under [HEIDENHAIN_ISO] and am able use them successfully.
Many thanks to Artur Koziol.
"the gift of God is eternal life through Jesus Christ our Lord"
Offline reuelt
  •  520 520
Re: EdytorNC support for MACH3 in NEXT release?
« Reply #1 on: April 30, 2019, 06:39:54 PM »
(See attached for e.g. of Mach3 tips)
EdytorNC is (FREEWARE) text editor for CNC programmers. Some features : bolt holes calculation; solutions of triangles calculation; speed, feed calculation; conversion inch/mm, mm/inch; code colouring; RS232 data transmission with automatic file saving and possibility to download new CNC program directly from machine (beta function, look in tool tips in serial port configuration dialog).
Clipboard to keep texts from system clipboard.
Features
RS232 data transmission with auto save and file server
code colorizing
side by side file comparison
"MACH4 Industrial" Users can just use the [FANUC] tool tips - since MACRO B Gcode tips are included there already.
« Last Edit: April 30, 2019, 06:45:01 PM by reuelt »
