Hello Guest it is November 23, 2026, 02:26:19 PM
Author Topic: Config>Homing/Limits -Reversed? and Ports&Pins >Kernel Speed?  (Read 8001 times)
Wondering what this Option does? When I check Reversed, it seems there is no effect. I have noticed that tweaking the other settings require me to close and reopen Mach3 before they take effect.
Under Port Setup, when I try to set the Kernel speed to 100Hz, the setting never stays. I tried this on two different computers, with CPU speeds >3 GHz, and my licensed file installed.
Are these somehow related?
