Hello Guest it is October 11, 2026, 10:27:48 AM
Author Topic: Dust hood  (Read 40271 times)
Re: Dust hood
« Reply #30 on: May 28, 2019, 06:45:05 AM »
No rush on my account, Peter!
Andy
Offline Rob G
  •  17 17
Re: Dust hood
« Reply #31 on: May 28, 2019, 03:53:24 PM »
If you use the router profile that comes with Mach4, you will have outputs and macros for a dust hood already built in.
Offline Rob G
  •  17 17
Re: Dust hood
« Reply #32 on: May 28, 2019, 03:56:05 PM »
The router profile that comes with Mach4, will come with  dust hood already set up in it.  there is a button on the screen with outputs, and macros in the macros folder.  You will just need to map what you have.
Re: Dust hood
« Reply #33 on: May 31, 2019, 05:01:18 AM »
Hi all,
yesterday I finally menaged to run log file and I found out what the problem was. On my external control panel I have a push button to release tool from spindle. This input goes to pokeys and in PMC I have a ladder code to control the valve output (ESS port3pin3 ). When the button input was not active, the PMC code was deactivating port3pin3 many times per second.
 In log file the output for dust hood was activated correctly (port3pin2), but when the output was deactivated there was no event in log file for deactivating output port3pin2.
So my guess is that when the output 3 was deactivated so many times it also at one point deactivated output 2.
I've corrected the code and for now everything works as it should. Attached is the picture of PMC code that didn' worked in my case.
Thanks everyone for helping me specialy Andy to remind me to run log file  ;D
Peter
Re: Dust hood
« Reply #34 on: May 31, 2019, 10:14:35 AM »
Hi Peter,
I am glad to hear that it was an easy fix!
Yeah, I use the log file all the time, it helps a lot to figure out what is going wrong!
Andy
Re: Dust hood
« Reply #35 on: May 31, 2019, 10:38:27 AM »
hi
i little confuse ,before you said you use ESS  now you write pokeys
maybe mistake?
Re: Dust hood
« Reply #36 on: June 03, 2019, 12:15:27 AM »
I'm using ESS board. Pokeys56u is just for external panel buttons input.
Peter
Re: Dust hood
« Reply #37 on: June 03, 2019, 12:20:24 AM »
Why not use pokeys cnc ? Have 24 inputs ,i not work at pokeys i just use it and interesting why use ESS in that case?
Re: Dust hood
« Reply #38 on: June 03, 2019, 12:34:38 AM »
when I've buld my cnc 9 years ago there was no pokeys cnc board available. So I've decided to use ESS and for external panel pokeys56u.
Peter
