Hello Guest it is October 13, 2026, 11:12:08 PM
Author Topic: Jog Rate Override  (Read 9254 times)
Offline RMT
  •  13 13
Jog Rate Override
« on: August 30, 2007, 04:38:17 PM »
Is it possible to apply the feedrate override to the jog rate, so that there would be a button that applies the lowered feedrate also to the jograte and an led that inticates that you are jogging at the lower rate set int the feed rate override?
I'm working with the simple 3 axis screen and the only way to jog in continious mode is full bore.
I created a button and tried oem code 287  rapid override but it doedn't affect the jog rate neither does oem 202 feed override jog whatever that means.
Thanks for any help
Frank
