Hello Guest it is October 30, 2026, 08:47:35 AM
Author Topic: CNC Cut to length Saw Screen and Wizards......  (Read 60819 times)
Re: CNC Cut to length Saw Screen and Wizards......
« Reply #10 on: July 19, 2012, 08:48:45 PM »
Pics of your machine and setup please  :)
« Reply #11 on: July 20, 2012, 08:39:38 AM »
Hello Guys,
Maybe someone can help me (give me discount for my poor English)
I'm trying to do a kind of control similar to Scott's idea - it's a Cut to Length saw and i'm stuck on a routine.
The main screen has 10 pairs of fields for orders entry - one is lenght to cut, other is quantity
First I need to make the machine execute (for example) 3 cuts of 100mm each (first pair of input fields), and them proceed to the next order entry, but I don't know how to make system wait for the blade finnish a cut, advance another increment (of the same batch) restart to cut till the end of that Batch, and then jumps to a new order and so one.
I tryed to do the code below, and will apreciate if someone can point me some ideas.
I inagine to put a sensor at the end of the cut, when the Disc goes below table signaling Mach3 that cut reached end and at this moment a pressure clamp releases wood plate, X advances to next lenght of cut at same time blade returns to start position and process beguins with new lenght increment.
First part it's a kind of control like if blade thick is = 0 shows an error message...
Second part I used M3 for start motor blade (and for example activate signal 1 for pneumatic pressure clamp) - M5 to stop blade.
Tanks,
Fabio
Code: [Select]
'calcula e executa cortes
Sub Main ()
Esp_serra=GetUserDRO (1300)
  If Esp_serra=0 Then
  Message ("Largura da Serra não pode ser 0")
  Exit Sub
End If
Avanco=GetUserDRO (1301)
  If Avanco=0 Then
  Message ("Velocidade de Avanço não pode ser 0")
  Exit Sub
End If
Tam_chapa=GetUserDRO (1000)
  If Tam_chapa=0 Then
  Message ("Tamanho da Chapa não pode ser 0")
  Exit Sub
End If
Comp_corte=GetUserDRO (1001)
Vezes=GetUserDRO (1101)
Dist=GetDRO (0)
Andar=(Dist-(Comp_corte+Esp_serra))
If vezes>0 Then
  Code "M3"
  Code "G90"
  Code "G01 F" & Avanco & "X" & Andar
  Code "M5"
  vezes=(vezes-1)
  SetUserDRO (1101,vezes)
  End If
End Sub
« Reply #12 on: July 20, 2012, 09:04:32 AM »
Hey Russ,
   I my (VB)code, and on the screen, there is a DRO for entering you Saw Kerf thickness........
Please open up my "Post Code" button, and look at the VB, I have the Kerf in there, but perhaps the math is wrong....
if so, feel free to fix it. I am at work, and kinda burried for a bit, so can't really get into it at the moment.
scott
« Reply #13 on: July 20, 2012, 09:26:43 AM »
Ok Scott, thanks.
I'll post back if I cant get it fixed.
Russ
« Reply #14 on: May 04, 2013, 11:53:21 AM »
Does this work? I can't seem to get it to do anything.
I have been tasked with refurbing an automatic extrusion saw, but it is missing the control panel.
