Hello Guest it is November 13, 2026, 09:36:09 AM
Author Topic: Z axis move that should not be there  (Read 15094 times)
Offline klmark
  •  107 107
« on: August 28, 2007, 09:06:59 AM »
Hello everyone
 I am using the Mach ver 2.4 If I clean up a part in LC every thing looks right and post it to Mach I get Z axis move in the middle of the part cutting it stops moves the Z axis up back down and waits  for the cycle start button witch is alright but the z axis move should not be there any one els had that problem
                                    klmark
Re: Z axis move that should not be there
« Reply #1 on: August 28, 2007, 09:14:55 AM »
Is it in your code to move the z? If not, check your safe z settings. Also, post your code with a note of where you think it is going wrong.
Offline klmark
  •  107 107
« Reply #2 on: August 28, 2007, 10:18:06 AM »
Hi
Here is the file if you look at the file I spaced  the code in the file that should not be there and it is in the code I did delete some cod in the file so it is not that big it move the z axis up and down with no X and Y movement between the up an down
          klmark
Offline GaryB
  •  108 108
« Reply #3 on: August 28, 2007, 10:53:49 AM »
you might check your drawing that you created the g-code from and see if there is a break in the line at that location (open vector), that would cause it to lift up in z and move from y14.9966 to y 14.9967 as in your code
« Last Edit: August 28, 2007, 01:21:14 PM by GaryB »
Beckwith Decor Products
ArtCam Trainer
Onsrud & Custom CNC tooling Distributor
Wichita/Derby Kansas
http://www.beckwithdecor.com
Offline klmark
  •  107 107
« Reply #4 on: August 28, 2007, 02:10:56 PM »
Hi
 I created the G code in LC every thing looks good in LC
                                klmark
Offline GaryB
  •  108 108
« Reply #5 on: August 28, 2007, 03:07:21 PM »
I don't use LC but does it have an option to check for open vectors?
Due to the short movement in your code I suspect you have an open vector, enough to give you a z movement.
If you want to post the dxf drawing or email it to me I'll look at it for you.
gary
ArtCam Trainer
Offline klmark
  •  107 107
« Reply #6 on: August 28, 2007, 03:13:46 PM »
Hi
Here is the DXF file let me know what you found out
                   klmark
Offline GaryB
  •  108 108
« Reply #7 on: August 28, 2007, 03:54:39 PM »
I found no open vectors in your drawing, they were all fine.
Maybe someone that works with LC can help you. Try rotating or moving the vectors and generating the g-code again and see if that helps
ArtCam Trainer
Offline klmark
  •  107 107
« Reply #8 on: August 28, 2007, 04:57:56 PM »
It would be nice if Art or Brain would see the problem . As of rotate the part that is a no no because the part is nested on a sheet to save matrial
   klmark
