Hello Guest it is October 20, 2026, 03:07:28 PM
Author Topic: Vacuum on Flooding  (Read 8678 times)
Vacuum on Flooding
« on: August 25, 2007, 11:03:48 AM »
Is it possible to have like a SSR Relay hooked up to some pin (like Flood) and have it periodicaly sucking up the dirt automaticaly.
I mean I don't want to reinvent the wheel. But can somebody head me the right direction. Just like the Spindle enable/disable .
And you probably have to insert the gcode manualy, right ?
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Vacuum on Flooding
« Reply #1 on: August 25, 2007, 02:35:18 PM »
Well - yes it is.  If you look at the video tutorials it shows you how to hook up inputs and outputs.
You could also run a script on a G code or M code to do just this.
Look at the tutorials.
The other way, of course is to do it manually when you see a problem.
