Hello Guest it is November 21, 2026, 03:17:05 PM
Author Topic: No motion after Hicon Integra update - Mach3  (Read 25714 times)
« on: April 22, 2019, 10:58:35 AM »
In the process of chasing down a problem with interpolating a circle I updated the firmware to 3.26b and .xsvf to IntegraFPGA_7E7B
Integra 7766 & 7737 ,  Maxsine drives & motors
Aside from the circle error everything was fine before the updates. I am embarrassed to say that I didn't make a record of the motor settings in the Hicon plug in and I am pretty sure that is where my problem is. What should the index & output be for 3 axis?
Re: No motion after Hicon Integra update - Mach3
« Reply #1 on: April 22, 2019, 01:15:07 PM »
I have found a few differences in the pin mapping between the older version of the 7737 manual and the newer. Is there something I should be changing here?
« Reply #2 on: April 22, 2019, 05:10:29 PM »
I decided better to move forward than backwards, I am upgrading to Mach4
