Hello Guest it is November 07, 2026, 02:16:44 AM
Author Topic: screen design problem  (Read 16071 times)
Offline EL34
  •  10 10
« on: August 23, 2007, 09:43:14 PM »
I designed a mach3 screen with screen4.exe on one PC and it displays fine on that PC in mach3
I copied the background.jpg image used in that screen and the customscreen.set file to the actual machine I use mach3 on, over my network.
The .set file is in the mach3 folder and the background.jpg is in a folder under the mach3/bitmap folder.
I open the custom screen on the mach3 pc and it's all messed up.
Hard to describe but it looks like the screen is split in the middle and there are two sets of buttons on the screen.
Nothing is in the proper location.
It looks fine on the design PC but not right on the actual machine PC.
What should I look for to correct this. Not sure where to go from here.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: screen design problem
« Reply #1 on: September 03, 2007, 06:14:04 PM »
Hey EL34,
Are you usig the Auto Screen Enlarge?
If so either post a screen shot or send me the screen if you'd like.
