Hello Guest it is November 22, 2026, 02:27:25 PM
Author Topic: I need to cut 3D!!!  (Read 10111 times)
I need to cut 3D!!!
« on: August 23, 2007, 08:37:40 PM »
I am using a bench top vertical mill with Mach 3 and lazycam. I am drawing with AutoCad. I am not capable of drawing in 3D with autocad. What I would like to do is cut ramps-slopes in foam. I am willing to invest in new programs if I need to, but I would like to do it with what I have. Is this possible?
Re: I need to cut 3D!!!
« Reply #1 on: August 26, 2007, 07:31:27 PM »
If you learn to model in 3D in AutoCAD, then you'll need a 3D CAM program like Meshcam to create the g-code.
« Reply #2 on: August 26, 2007, 10:33:56 PM »
Have you tride Meshcam art?
