Hello Guest it is October 20, 2026, 11:01:59 PM
Author Topic: Trust in the LORD V-carving sign for free sharing  (Read 48310 times)
Offline reuelt
  •  520 520
« on: April 21, 2019, 09:02:24 PM »
Attached is gcode file generated by FREEWARE F-engrave (a poor man's VCarve Pro)
Material should be flat and at least 204mm x 150mm in size
Tool used is a cheap 22mm 60deg CNC V-Carve bit from ebay (you may substitute with 60deg 3/4" V-Carve bit)
Origin is mid-center  and z =0 is on top of the surface.
F =600 mm/min and S =12,000 rev/min cuts MDF well.
Change F & S to suit your material.
« Last Edit: April 21, 2019, 09:10:51 PM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
