Hello Guest it is November 22, 2026, 10:37:19 AM
Author Topic: "run from here" problem  (Read 126794 times)
Offline jeremyrockjock
  •  39 39
  • Why buy what you can build.
Re: "run from here" problem
« Reply #10 on: January 08, 2012, 05:18:57 PM »
Thanks for the quick reply. If I try to scroll in the window with the reset button pressed "not blinking" it will not let me scroll down. It will only scroll if the reset and its blinking.
« Reply #11 on: January 08, 2012, 05:22:47 PM »
Something wrong there, if you attach your xml I will see how it works here and maybe can find the issue.
  •  39 39
« Reply #12 on: January 08, 2012, 05:45:04 PM »
Forgive my ignorance but how do I do that?
« Reply #13 on: January 08, 2012, 05:47:11 PM »
Ok open Mach and look lower right for the profile name. Look in the mach3 folder on your drive for a file with that name and a xml extension. Copy it to your desktop and rename to jeremyrockjock.xml and then use the additional options on the reply page to browse and attach.
  •  39 39
« Reply #14 on: January 08, 2012, 05:55:14 PM »
Okay Thanks alot.
« Reply #15 on: January 08, 2012, 06:00:06 PM »
Seems to be fine here, are you just using the parallel port?
Might be worth trying the standard plasma screenset or maybe even a different keyboard.
  •  39 39
« Reply #16 on: January 08, 2012, 06:09:32 PM »
I have parallel ports 1 and 2 for the THC300.
I unplugged the keyboard and tried to scroll but no go. I also switched the screens to plasma.
« Reply #17 on: January 08, 2012, 06:12:01 PM »
I just tried with the scorpion code in Mach and it worked fine, maybe something in your  code although I dont know what it could be. If you attach some code I can test with it.
  •  39 39
« Reply #18 on: January 08, 2012, 06:20:39 PM »
Here is the file I was running today.
« Reply #19 on: January 08, 2012, 06:30:10 PM »
Ok its not working with that code, I need to get some sleep but will have a look at the code tomorrow. Having said that I am crap with code ;D
I can scroll with the slider and click a line but when I press RFH it starts at line 4.
