Hello
Guest
it is
November 22, 2026, 10:27:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
"run from here" problem
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
Go Down
Author
Topic: "run from here" problem (Read 126790 times)
jeremyrockjock
39
Why buy what you can build.
Re: "run from here" problem
Reply #10 on:
January 08, 2012, 05:18:57 PM »
Thanks for the quick reply. If I try to scroll in the window with the reset button pressed "not blinking" it will not let me scroll down. It will only scroll if the reset and its blinking.
Logged
Carnoustie, Scotland
Reply #11 on:
January 08, 2012, 05:22:47 PM »
Something wrong there, if you attach your xml I will see how it works here and maybe can find the issue.
Logged
jeremyrockjock
39
Reply #12 on:
January 08, 2012, 05:45:04 PM »
Forgive my ignorance but how do I do that?
Logged
Reply #13 on:
January 08, 2012, 05:47:11 PM »
Ok open Mach and look lower right for the profile name. Look in the mach3 folder on your drive for a file with that name and a xml extension. Copy it to your desktop and rename to jeremyrockjock.xml and then use the additional options on the reply page to browse and attach.
Logged
jeremyrockjock
39
Reply #14 on:
January 08, 2012, 05:55:14 PM »
Okay Thanks alot.
Logged
Reply #15 on:
January 08, 2012, 06:00:06 PM »
Seems to be fine here, are you just using the parallel port?
Might be worth trying the standard plasma screenset or maybe even a different keyboard.
Logged
jeremyrockjock
39
Reply #16 on:
January 08, 2012, 06:09:32 PM »
I have parallel ports 1 and 2 for the THC300.
I unplugged the keyboard and tried to scroll but no go. I also switched the screens to plasma.
Logged
Reply #17 on:
January 08, 2012, 06:12:01 PM »
I just tried with the scorpion code in Mach and it worked fine, maybe something in your code although I dont know what it could be. If you attach some code I can test with it.
Logged
jeremyrockjock
39
Reply #18 on:
January 08, 2012, 06:20:39 PM »
Here is the file I was running today.
Logged
Reply #19 on:
January 08, 2012, 06:30:10 PM »
Ok its not working with that code, I need to get some sleep but will have a look at the code tomorrow. Having said that I am crap with code
I can scroll with the slider and click a line but when I press RFH it starts at line 4.
Logged
Print
Pages:
1
2
3
4
5
6
7
8
Go Up
« previous
next »
