Hello Guest it is November 13, 2026, 03:52:12 PM
Author Topic: Spindle Relay Configuration Questions  (Read 39124 times)
Re: Spindle Relay Configuration Questions
« Reply #20 on: May 02, 2019, 09:03:29 AM »
You should connect the BOB ONLY to a 12-24V power supply.
and DO NOT CONNECT a USB CABLE TO THE PC!
(i will explain to you why via PM if you want to know)
Yes, I would like to know.  While I appreciate you sending me the BoB manual it doesn't do a good job of explaining the boards functions.
Tom
Offline TPS
  •  2,627 2,627
« Reply #21 on: May 02, 2019, 11:23:29 AM »
Currently my spindle direction is controlled with a switch (FWD-OFF-REV) and speed is with a potentionmeter.
so there must be a Kind of Controller, maybe it has got control Inputs to Switch ON/OFF instead of switching
the powersupply. just a thought.
