Hello Guest it is November 22, 2026, 11:21:49 AM
Author Topic: Version 2.4.2  (Read 12367 times)
Version 2.4.2
« on: August 22, 2007, 02:04:13 AM »
Art, I downloaded the latest version 2.4.2 as an update and there seems to be a bug. Whenever I try to change the screen set from the standard version to the plasma screen set. The program momentarily hangs up, then nothing. It stays the same. I've tried all of the other screen sets to see if is just the plasma set to no avail. The reason I like the plasma screen on my mill is because of the large tool path display. It's easier on the eyes for those of us with poor eyesight.
Re: Version 2.4.2
« Reply #1 on: August 22, 2007, 03:26:02 PM »
I have tested it here and it is working fine... Could you please post the set file that you are trying to load?
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: Version 2.4.2
« Reply #2 on: August 22, 2007, 04:26:33 PM »
Here is the 1024.set file that came with my original installation. Up until I upgraded to the latest version. It worked beautifully.
Re: Version 2.4.2
« Reply #3 on: August 23, 2007, 08:49:02 AM »
loaded no problem here... please be sure that you have the set file in the Mach3 directory
Brian
www.machsupport.com
Re: Version 2.4.2
« Reply #4 on: August 23, 2007, 05:23:29 PM »
I need to apologize Brian, it wasn't the plasma.set file that was the problem or the version 2.4.2 upgrade. When I upgraded I didn't notice  that it over wrote my display file with the standard .set viewer file. It turns out that the the Simple 3 axis Screen file that I mistook for the plasma file was over written. Sorry for any inconvienence.
