Hello
Guest
it is
September 17, 2026, 06:29:24 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
NFW request
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: NFW request (Read 32189 times)
vmax549
NFW request
on:
August 20, 2007, 07:59:39 PM »
Ron while using the NFW suites it seems that the wizards assume that the "top of work" Z value is always Zero. This makes it hard to integrate the wizard code into other Gcode programs. Could you change that to have an input for the top of work Zvalue?
Thansk (;-) TP
Ron Ginger
925
Re: NFW request
Reply #1 on:
August 21, 2007, 02:57:01 PM »
If you mean for every wizard in the set, I think I'm to old to start a project like that. :-)
I did look at adding a Ztop to the surfacing wizard, I may be able to add that when I finish the step over problem.
vmax549
Re: NFW request
Reply #2 on:
August 21, 2007, 03:56:48 PM »
Hi Ron , I am not a wizard at programing BUT it seems that it should only be a few lines of code and a entry dro. You are only substituting a variable for a set value. Pretty please
You can't be that old(;-) I am as old as dirt and I did not see you splashing around in the water when I poped up.
Print
Pages:
1
Go Up
« previous
next »
