Hello
Guest
it is
October 20, 2026, 09:39:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Tool Change Output
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Tool Change Output (Read 12962 times)
olf20
325
Tool Change Output
on:
August 18, 2007, 05:35:53 PM »
When my machine comes to a tool change it will stop and wait till I change the tooling.
Is there a way to trigger one of the extra outputs (maybe spindle on / off) so I can also stop and start my router motor and
vaccum system?
I know I can enter the code at every tool change in the program but I was wondering if when Mach3 came
to a tool change it could be configured to turn on / off one of the outputs on my breakout board.
We run the machine during store hours and sometimes we are waiting on customers when
its time to change to the next tool.
I have solid state relays with 3 - 15 volt input and 25 amp rating.
Thanks for any help!!
olf20
Last Edit: August 18, 2007, 05:37:58 PM by olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
vmax549
Re: Tool Change Output
Reply #1 on:
August 18, 2007, 06:04:11 PM »
Using the M6stop, M6start macros you can program whatever sequence you need during a tool change. The hardware side has to be hooked up though to work.
olf20
325
Reply #2 on:
August 18, 2007, 06:59:21 PM »
Thanks vmax549!!
How do I access the Macro, I have never delved into this part.
Thanks again!
olf20
Chaoticone
5,624
Precision Chaos
Reply #3 on:
August 18, 2007, 07:13:18 PM »
Olf,
Open Mach. look at the tabs at the top, operator, vb script editor, browse to mach 3 folder, macros, the profile you are using. Should find M6 start and M6 end there.
If you could see the things I have in my head, you would be laughing too.
olf20
325
Reply #4 on:
August 18, 2007, 08:48:27 PM »
Thanks Chaoticone!
I found exactly what you described. Now I have to learn about VB Scripting.
I know that there are some examples on the forum. I'll do some searching.
Thanks Again!
Reply #5 on:
August 19, 2007, 12:51:08 AM »
Not very good at VB myself but if you have your vacuum and spindle working from code already it should work by just putting the code in the macro, the example below should switch off the spindle and stop coolant (I am presuming you have your vacuum connected via the coolant on/off).
code "m5"
code "m9"
As I said I am not good at VB but pretty sure that will work.
Print
Pages:
1
Go Up
« previous
next »
