Hello Guest it is November 07, 2026, 10:41:07 AM
Author Topic: move to new layer  (Read 10548 times)
Offline docltf
  •  354 354
move to new layer
« on: August 18, 2007, 05:00:05 PM »
BRIAN
       is it possible to fix lcam pro so that when you use sel in box, that after you select your chains you can right click the mouse
       and select move to new layer.and also be able to do the same thing when using single/multiple setting.
thanks bill
Re: move to new layer
« Reply #1 on: August 18, 2007, 08:25:29 PM »
We can look into that ... I can see where that could be a big help.
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline docltf
  •  354 354
« Reply #2 on: August 19, 2007, 12:36:54 PM »
BRIAN
        can you also do a right click zoom in the project window, so that when you zoom a layer or a chain the selection
       will be as large as it can get in the display window and hide the rest of the drawing.this will help when trying to
       clean up a dxf from a scanned image.
bill
« Reply #3 on: August 20, 2007, 08:58:27 PM »
I don't think I understand what you are looking for :(
Sorry
Brian
www.machsupport.com
Offline docltf
  •  354 354
« Reply #4 on: August 20, 2007, 11:37:52 PM »
the left window where the chains and layers are.when you left mouse click a chain it highlights the chain in the display window.can you
put a right click that will  full zoom. and when you pick a chain you can zoom the chain only.and if you pick a layer it will only zoom
that layer.
thanks bill
