Hello Guest it is August 24, 2026, 03:35:02 PM
Author Topic: limit Switch triggered error  (Read 22887 times)
« on: April 04, 2019, 12:12:57 AM »
Hi
i am new to cnc router. i have installed my machine but it shows following errors. please guide how to resolve the issue.
Offline reuelt
  •  520 520
Re: limit Switch triggered error
« Reply #1 on: April 04, 2019, 01:02:19 AM »
What machine are you using?
Parallel port or external motion controller (USB or Ethernet)? Please name model.
Anyway,
Turn off your machine power OFF (NOT the computer - just the router).
Now if you are using stepper motors, Manually turn or crank each motor so that no axis X , Y, Z etc have the limit switch triggered. Just move a little distance.
Now power router on
In MACH3
Click [reset] button
Click [ref. all] button
Let us know how it goes.
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #2 on: April 04, 2019, 03:36:40 AM »
I am using Parallel port and now this issue is solved but another issue arises as i start Mech 3 an error message plugin DLL defective message come to seen. I am using steeper motor. Please help
Offline reuelt
  •  520 520
« Reply #3 on: April 04, 2019, 04:54:26 AM »
« Reply #4 on: April 04, 2019, 01:05:16 PM »
i am using window xp not windows 7
Offline reuelt
  •  520 520
« Reply #5 on: April 04, 2019, 02:59:06 PM »
Sorry,
" plugin DLL defective" may be because of old or illegal version of MACH3
Backup your profile (mach3mill.xlm) and license file (Mach1Lic.dat) and download latest version of Mach3 R3.043 from:-
https://www.machsupport.com/downloads-updates/main-programs/
When you are installing, disable antivirus, right click on Mach3Version3.043.exe and RUN AS ADMINISTRATOR
YOU MUST IMMEDIATELY REBOOT the PC after installation or else MACH3 parallel port driver will NOT work.
After reboot try testing again.
« Last Edit: April 04, 2019, 03:03:06 PM by reuelt »
« Reply #6 on: April 11, 2019, 08:55:49 AM »
hi my software issue is resolved now i am facing an issue regarding connectivity of my white cnc controller to the pc. now router cutter is working but his speed can be controlled from speed button on white controller but machine xyz axis motors are not doing any movement. parallel port drivers are showing working perfectly working. please suggest any method to test my port  and can to check any issue with my controller. please help
Offline reuelt
  •  520 520
« Reply #7 on: April 11, 2019, 02:03:46 PM »
Do you know what is your Break Out Board (BOB) Brand and model number?
Unless you have set up your "ports and pins" correctly, the machine is not going to move or do anything.
« Reply #8 on: April 12, 2019, 05:31:03 AM »
this is my controller mach 3 controller v 1.2
(edited to reduce size)
« Last Edit: April 12, 2019, 06:11:32 AM by Overloaded »
« Reply #9 on: April 12, 2019, 06:24:20 AM »
device manager showing these drivers /port setting
