Hello Guest it is November 25, 2026, 06:04:39 AM
Author Topic: os.execute pdf  (Read 7908 times)
Offline gorf23
  •  190 190
os.execute pdf
« on: April 02, 2019, 09:16:06 PM »
is there a way to run a pdf file from a button?
Tried os.execute but can't seem to get that to work.
Thanks gary
Re: os.execute pdf
« Reply #1 on: April 03, 2019, 07:51:31 AM »
Code: [Select]
local major, minor = wx.wxGetOsVersion()
    local dir = mc.mcCntlGetMachDir(inst);
    local cmd = "explorer.exe /open," .. dir .. "\\Docs\\MyDoc.pdf"
    if(minor <= 5) then -- Xp we don't need the /open
        cmd = "explorer.exe ," .. dir .. "\\Docs\\MyDoc.pdf"
    end
    wx.wxExecute(cmd)
Offline gorf23
  •  190 190
Re: os.execute pdf
« Reply #2 on: April 03, 2019, 10:43:52 AM »
Yes I tried that also but couldn't run that from a button... there was some sort of restriction couldn't be run from ? forgot the message..
I did get the os.execute to work turns out windows firewall was blocking it from running,,
thanks gary
Re: os.execute pdf
« Reply #3 on: April 03, 2019, 12:21:42 PM »
Hello Gary,
Create a function in the screenload script with the script provided in Chaoticone's comment. Then, use a button to call the function.
It is also worth mentioning that the path included in that script requires your document to be in the Docs subfolder in your Mach4 directory.
-B
Newfangled Solutions Helpdesk: http://support.machsupport.com
YouTube Support Channel: https://www.youtube.com/c/MachSupportOfficial
Offline gorf23
  •  190 190
Re: os.execute pdf
« Reply #4 on: April 03, 2019, 12:52:42 PM »
ok thanks will try that i was using it in the button script itself will put in the screen load script.
Also i do already have the file in the docs folder..
Thanks Gary
