Hello Guest it is October 22, 2026, 03:36:26 PM
Author Topic: Z axis when I start Gcode just plunges into work  (Read 8368 times)
« on: March 29, 2019, 06:51:52 PM »
Hello so I have not really had much luck getting my machine set up properly. I try running the skull and crossbones it runs through the code but it never touches the work piece. So I try some Gcode that I created which is just a circle .25 deep and it just plunges into work piece and bottoms out.  Any help would be great
« Last Edit: March 29, 2019, 06:53:58 PM by Stvktchn »
Offline reuelt
  •  520 520
Re: Z axis when I start Gcode just plunges into work
« Reply #1 on: March 29, 2019, 07:34:22 PM »
Are you using MACH3 or MACH4?
Normally, you need to jog (TAB key will give you Jog screen + arrow keys to jog) to the zero point of your workpiece at set work coordinates to zero.
Z = 0 is when your bit just touch the surface of the workpiece.
regenerate tool path
Then Cycle Start
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #2 on: March 29, 2019, 08:02:50 PM »
Mach 3.   Ok I will try that thank you
