Hello
Guest
it is
October 15, 2026, 03:47:14 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
wx lua error when lua newfangled solutions plugin is enabled
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: wx lua error when lua newfangled solutions plugin is enabled (Read 14313 times)
smurph
1,575
"That there... that's an RV."
Re: wx lua error when lua newfangled solutions plugin is enabled
Reply #10 on:
July 03, 2019, 07:22:31 PM »
If it doesn't compile the mcs files, then there is a syntax error in one of them. You will have to open each one individually and try to compile them (with mcLuaEditor, not ZeroBrane) to see which one is giving the error.
Steve
Logged
gorf23
190
Reply #11 on:
July 05, 2019, 10:25:51 AM »
Thanks I ended up moving all the macros and putting them back one by one till I found the bad one..
All is good now
Gary
Logged
Print
Pages:
1
2
Go Up
« previous
next »
