Hello Guest it is September 06, 2026, 07:02:17 AM
Author Topic: M3 not working, but M4 is working. Both use same output for analog signal  (Read 8189 times)
Offline kf2qd
  •  157 157
Had an interesting one today. Went to run the spindle and got no output from M3. M4 works just fine, as I have no relay connector for reverse so it gives me forward... Both are assigned pin fourteen, port 1 and M3 worked just fine a couple days ago. I am using a Smoothstepper and have made no changes to its config since M3 last worked.
Offline kf2qd
  •  157 157
Sorry for the delay - Changed nothing and now M3 works.Rebooted teh machine several times the first day and no change - Went to the shop the next and wanted to try some thread milling and it works just fine...
Offline reuelt
  •  520 520
Is your Mach3 the latest patched version of Mach3Version3.043.062 ?
Sometimes workings sometime not working is NOT good.
"the gift of God is eternal life through Jesus Christ our Lord"
