Hello Guest it is October 22, 2026, 09:40:14 PM
Author Topic: mach4 m6 tool select issue  (Read 5735 times)
« on: March 14, 2019, 05:29:29 PM »
I've realized what I've been doing wrong. all sorted!
« Last Edit: March 14, 2019, 05:48:05 PM by gfosdike »
Re: mach4 m6 tool select issue
« Reply #1 on: March 14, 2019, 05:53:19 PM »
there are two interpretations you can use with the 'T' word.
The first and most common to you and I (and any one else coming from a Mach background) is that the T word
is the tool number that will end up in the spindle when the toolchange is complete.
So:
m6 t5..........will result in tool 5 being fitted into the spindle.
There is another interpretation that is common in production machines. In that situation its common for the T word
to be the tool number of the NEXT toolchange. This would cause the tool carousel to be pre-positioned and therefore
speed up the toolchange.
Have a look  at Configure/Control/Tools
