Hello Guest it is November 22, 2026, 02:26:11 PM
Author Topic: Lazycam doesn't recognise Mach3  (Read 8597 times)
« on: March 12, 2019, 12:15:27 PM »
When I post the code to Mach3 I get the note as 'Can't post - no Mach3 running'
It clearly is running but why can't Lazycam see it? Any suggestions please
Offline reuelt
  •  520 520
Re: Lazycam doesn't recognise Mach3
« Reply #1 on: March 16, 2019, 02:36:05 AM »
TRY starting Lazycam from within Mach3
File Lazycam..
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #2 on: March 16, 2019, 03:43:41 AM »
Mach3 is loaded via the Mach3 loader and Lazycam is loaded from within Mach3 so any other suggestions please?
Offline reuelt
  •  520 520
« Reply #3 on: March 16, 2019, 09:20:20 AM »
Did you install lazycam when you installled MACH3 or did you installed lazycam separately afterwards?
Do you buy the Pro version lazycam license?
Did you buy the MACH3 or are you still on demo version?
Lazycam (std) will not save, if the MACH3 license is invalid.
Offline reuelt
  •  520 520
« Reply #4 on: March 16, 2019, 02:38:20 PM »
If you are using Windows 7 or higher,
Right click on lazycam's short-cut and select prperties | compatibilities
run lazycam as a "windows XP Sp2" and tick run as administrator.
