Hello Guest it is November 25, 2026, 09:01:48 AM
Author Topic: ATC help  (Read 9260 times)
ATC help
« on: March 12, 2019, 04:50:54 AM »
I am working on a tool change script  my problems are
I need to delay or wait till a input comes on and I do not know how to do that I think I can read the input and can certainly turn on and of the outputs
But cant figure out how to create a loop while waiting for a input to happen after I give a output command
Regards Ray
Re: ATC help
« Reply #1 on: March 12, 2019, 07:25:28 AM »
Check out the mcSignalWait API call in the Mach4CoreAPI.chm help file.
Re: ATC help
« Reply #2 on: March 12, 2019, 05:39:08 PM »
Yup, mcSignalWait is it!
If I remember, I'll post some of my ATC code tomorrow.
Anytime I use this call, I always check the rc.
For example, the ATC I just finished working on is all pneumatic, if the cylinder takes to long to extend or retract, I E Stop the machine, leave an error message, and return to the end of the Macro.
Again, I'll try and remember to post some code tomorrow.
Chad Byrd
Re: ATC help
« Reply #3 on: March 12, 2019, 05:54:58 PM »
Thanks for that I found the  Mach4CoreAPI.chm help file  that is what I need and the wait command will be perfect for what I want to do
Sorry for being such  a amateur I just need pointing in the right direction once in a while thanks again but now having the help files and knowing where they are located will help heaps
Regards Ray
Re: ATC help
« Reply #4 on: March 12, 2019, 05:59:08 PM »
that would be great mine is also air operated in part and will do as you suggest I had not thought of a E-Stop but this would be good if the air supply etc stopped for some reason or other problems as well
thanks
Re: ATC help
« Reply #5 on: March 12, 2019, 06:49:10 PM »
Yeah, for sure.   It can wait indefinitely, or you can set it tot wait for a certain amount of time before it continues.   When it continues on with the macro, you check the rc to see if it completed properly or if it timed out.  I have the code on a jump drive now, I'll post it when I get home.
« Last Edit: March 12, 2019, 06:51:08 PM by Cbyrdtopper »
Chad Byrd
Re: ATC help
« Reply #6 on: March 12, 2019, 07:07:38 PM »
Here it is.  Two parts of my m6 macro.
I get the handle of my outputs in the beginning of the macro; but here is a rundown of what is going on.
--Move the POT down.
mc.mcSignalSetState(POTUp, 0)
mc.mcSignalSetState(POTDown, 1)
rc = mc.mcSignalWait(inst, mc.ISIG_INPUT24, mc.WAIT_MODE_HIGH, ErrorWaitTime)
if rc ~= 0 then
   mc.mcCntlSetLastError(inst, "There was a problem moving POT down.")
   mc.mcSignalSetState(Alarm, 1)
   return
end--POT down error check.
--Move the arm to the spindle.
mc.mcSignalSetState(ArmToHome, 0)
mc.mcSignalSetState(ArmToSpindle, 1)
rc = mc.mcSignalWait(inst, mc.ISIG_INPUT26, mc.WAIT_MODE_HIGH, ErrorWaitTime)
if rc ~= 0 then
   mc.mcCntlSetLastError(inst, "There was a problem moving the arm to the spindle.")
   return
end--Arm to spindle error check.
rc = mc.mcSignalWait(inst, mc.ISIG_INPUT#, mc.WAIT_MODE_HIGH, ErrorWaitTime)
The "ErrorWaitTime" on the end of the call is a variable I have declared at the top of my macro.  It is read in seconds.  You can make it a variable or just put in an integer.  That is how long it waits before it continues on with the macro.  If it is left at 0 then it will wait indefinitely.
Chad Byrd
Re: ATC help
« Reply #7 on: March 12, 2019, 07:33:56 PM »
I usually put a helper function in my m6 script. I use it to check all return calls and then do what I want if it fails. This is what it could look like and example of using it.
Code: [Select]
function m6ErrorOut(msg)
mc.mcCntlMacroAlarm(inst, 6, msg)
end
Code: [Select]
rc = mc.mcCntlGcodeExecuteWait(inst, string.format("G1 G53 F%0.4f Z%0.4f\nG1 G53 Y%0.4f\n", changeFeedRate, zAtCar, yAtCar))
if (rc ~= 0) then
msg = mc.mcCntlGetErrorString(inst, rc) --Get the returned error string
m6ErrorOut(msg)
return
end
