Hello Guest it is November 26, 2026, 08:51:47 PM
Author Topic: Jogging A Axis ???  (Read 8929 times)
Jogging A Axis ???
« on: March 02, 2019, 03:28:19 PM »
I just installed and configured a 4th axis on the mill. Everything is setup and working perfectly. I can use MDI to move the axis but I cannot figure out how to jog the axis with the keyboard. Is there a set of keys that are already configured like X, Y, and Z or do I have to manually setup the A axis with the system hot keys.
read somewhere it was - and + but that did not work.
I also tried to search "jogging A axis" but the forum won't search unless all words are more than one character so that was zero help.
Thanks in advance.
Re: Jogging A Axis ???
« Reply #1 on: March 02, 2019, 03:57:34 PM »
Try Page Up and Page Down.
« Reply #2 on: March 02, 2019, 04:39:17 PM »
Page up and down is the Z axis.
Configured the A axis in system hotkeys and it worked. Then X, Y, and Z wouldn't work so I configured all 4 axis in system hotkeys and all is good now. Before this all were 999.
BTW the A axis is now + and -
« Reply #3 on: March 03, 2019, 10:25:15 AM »
Jeesh, sure you're right.  :P   ::)   (been a while .... sorry for the mis-info)
I saved a large file on your works. Very impressive !
I've been watching for your Allison V-1710 or Merlin build.  :)
Cool stuff.
Russ
