Hello Guest it is November 02, 2026, 06:28:48 AM
Author Topic: A Blue Question sign in device manager win7 32  (Read 29211 times)
« on: March 02, 2019, 05:26:34 AM »
Hi',
I have installed licensed  mach3 on my pc win7 32bit ram 3gb, and it is for my plasma cnc, keep getting this blue question mark in device manager. My bob is cnc4pc c35s with lpt port connection to pc. I have ran driver test, was fine, i did turn off power management, screen saver, win fire wall, it is only for mach3.  Did i miss something, ?anyone can help me to solve this same problem?
Thank you
Stefanus
Offline reuelt
  •  520 520
Re: A Blue Question sign in device manager win7 32
« Reply #1 on: March 02, 2019, 04:12:52 PM »
Go into command prompt with administrator rights and paste and add the below registers.
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v FeatureSettingsOverride /t REG_DWORD /d 3 /f
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v FeatureSettingsOverrideMask /t REG_DWORD /d 3 /f
Restart the computer for the changes to take effect.
(I got this from post by another forum member)
"the gift of God is eternal life through Jesus Christ our Lord"
Offline reuelt
  •  520 520
« Reply #2 on: March 03, 2019, 01:34:31 AM »
 A Blue Question sign in device manager win7 32 just means "driver is NOT digitally signed" with Microsoft.
The 2 registry patches are to prevent Mach3 crashing because some new Win7 automatic updates will try to disable the "unsigned drivers".
After applying the two patches you can safely ignore the ? sign.
« Reply #3 on: March 03, 2019, 06:03:31 AM »
Hi Reulet, i have tried, but im getting an error syntax and not recignize, i think i was wrong in typing , anyway how to type it?
Thank you
« Last Edit: March 03, 2019, 06:07:01 AM by Tweakie.CNC »
  •  9,375 9,375
« Reply #4 on: March 03, 2019, 06:14:51 AM »
Hi Stefanus,
Welcome to the forum.
Just a general note to all...
It would be helpful if images were re-sized to 800 x 600 before posting to the forum. This thread relates;  https://www.machsupport.com/forum/index.php?topic=24585.0
« Reply #5 on: March 03, 2019, 06:22:00 AM »
Ook i will.
Thank you
Offline reuelt
  •  520 520
« Reply #6 on: March 04, 2019, 04:19:02 AM »
Find command prompt
right click and select RUN as Administrator
Use you mouse  highlight  the whole line then copy (cntr+C)
Now click you mouse at the command prompt field and
paste (Cntr+V)
Press enter
Do the same for the next reg add line.
If you are typing, reg add
must not have quotes
« Reply #7 on: March 04, 2019, 07:09:29 AM »
Hi Reulet,
It was succesful those two files installed. But the blue? Sign still there, i have restarted windows.
Thank you
Offline reuelt
  •  520 520
« Reply #8 on: March 04, 2019, 03:16:09 PM »
Hi Reulet,
Thank you
After applying the two patches you can safely ignore the ? sign. My win7 system has  the blue? sign too. Only Windows XP systems will NOT have that blue? sign.
« Reply #9 on: March 08, 2019, 06:54:05 AM »
Ook Thank you Reulet :)
