Hello Guest it is November 26, 2026, 04:53:09 AM
Author Topic: changing value in CurrentX dro  (Read 10498 times)
Offline Bill_O
  •  616 616
« on: February 28, 2019, 11:13:30 AM »
I have tried several things to get a specific number in the CurrentX dro.
G92 works but it also is an offset which messes up some other things.
Offline thosj
  •  542 542
Re: changing value in CurrentX dro
« Reply #1 on: February 28, 2019, 11:23:43 AM »
Have you tried clicking in the DRO and typing the number you want?
Tom
Tom
Offline Bill_O
  •  616 616
« Reply #2 on: February 28, 2019, 11:26:15 AM »
tom,
i need to do it within a lua script
in mach3 when i used g92 it behaved much different than it does in mach4
it all has to do with some positioning that i need to adjust multiple times
bill
Offline gorf23
  •  190 190
« Reply #3 on: February 28, 2019, 11:41:59 AM »
off the top of my head i think that I used something like this in a script
xpos = mc.mcAxisGetPos(inst, mc.X_AXIS) -- Get X Axis Position
scr.SetProperty("dro134","Value", tostring(xpos))
gary
Offline Bill_O
  •  616 616
« Reply #4 on: February 28, 2019, 01:00:13 PM »
Gary,
I will give that a try.
I tried using droCurrentX and that did not work.
Where did you find the dro numbers?
Bill
Offline Bill_O
  •  616 616
« Reply #5 on: February 28, 2019, 02:16:24 PM »
Gary,
That did not work but thanks for the assistance.
Bill
Offline gorf23
  •  190 190
« Reply #6 on: February 28, 2019, 03:11:06 PM »
screen edit just rename the  x dro name to whatever you like and replace your dro name with  scr.SetProperty("your dro name","Value", tostring(xpos))
gary
Offline Bill_O
  •  616 616
« Reply #7 on: February 28, 2019, 04:50:48 PM »
Gary,
I just made a new dro and it appears to be working.
Not sure why the one native to mach4 wouldn't do it.
Having another problem so I am not positive  it is working but it looks like it.
Bill
« Reply #8 on: February 28, 2019, 06:28:53 PM »
Make sure that the droCurrentX editor property is not still set as read only.  This was reported a year ago for the lathe screen set and wasn't changed the last time I downloaded a new version last fall.
Not sure what you are trying to do but I think you probably should be using mc.mcAxisSetPos(inst,mc.X_AXIS,10.3456) rather than changing screen  values.
Just my 2 cents worth
HTH
RT
