Hello Guest it is October 20, 2026, 09:44:51 PM
Author Topic: Warp9 ESS communicates will not give output signal, m3 crashes on poit config. S  (Read 7682 times)
I have purchased a license through NFS and installed everything via warp9. The LED indicated PC communication, top green solid bottom blinking, top red off bottom functions with software e stop. Db25 BOB and Ebay driver. Axis moves on mach 3 nothing outputs on motor or Bob with voltmeter. Video uploading to YouTube. Funny thing is lots of freeze and crash going out of any port configuration screen and motor config. The estop screen pops up and clicking ok to clear dialog freezes it up and have to end program. Need help. Table is ready
Chuck 906 420 3874
YouTube - Northern Racing Fabrication
https://youtu.be/61L0RSlc_wM
  •  9,374 9,374
Hi Chuck2302,
Welcome.
Could you also post your question on the Warp9 forum here; https://www.warp9td.com/index.php/kunena/7-general-discussion  (Andy will be able to give you detailed instruction on how to resolve the problem).
