Hello Guest it is October 20, 2026, 03:05:18 PM
Author Topic: How do I configure the A-axis settings?  (Read 11937 times)
« on: February 22, 2019, 09:56:19 PM »
What do I need to do in order to configure Mach3 to know when the rotary axis has done a full 360 degr. rotation?
Offline olf20
  •  325 325
Re: How do I configure the A-axis settings?
« Reply #1 on: February 25, 2019, 06:13:03 AM »
Its been awhile but in the general settings you check
or uncheck Rot Roll Over. There are other settings,
so ask away.
olf20 / Bob
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
« Reply #2 on: February 25, 2019, 08:09:04 AM »
I need also to know which values to set in the Motor Tuning and Setup/A-axis motor movement profile?
My rotary table requires 72 rotations from the stepper motor in order to move 360 degr. so what do I need to set in "steps per". and the other windows there?
I use the Gecko G540 as driver for the stepper motors..
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: February 25, 2019, 09:38:33 AM »
Lets see if the old grey matter is still working.
It is best to set your steps for a 1 degree movement so if you need to move 72 motor revs per 360 degrees then its 72 X 200 steps (or what ever your steps per 1 rev of the motor) divided by 360 this is your steps per 1 degree which would be 40
If you turn off 'roll over' and 'short path' then you can command A720.0 or A1440.0 and it knows its to do and done 2 revs or 4 revs of the axis, it will also do 2 or 4 revs back if you command A0
Graham
Offline olf20
  •  325 325
« Reply #4 on: February 25, 2019, 10:56:27 AM »
I knew that someone (with far more knowledge) would
jump in and list all the details.
olf20 / Bob
« Reply #5 on: March 02, 2019, 02:25:42 PM »
I tried the settings that already was in the config. page and after turning the rotary table a full rotation, I calculated the right setting to be 400 steps per unit, and it looks like that is the right one, but I don“t understand how this number could be the right.
Does that mean that I have 2000 microsteps in my drivers?
  •  2,785 2,785
« Reply #6 on: March 03, 2019, 07:29:16 PM »
I think the 540 defaults to 10 micro steps which would give 2000 steps on a standard 200 step motor.
« Last Edit: March 03, 2019, 07:33:38 PM by Graham Waterworth »
