Hello Guest it is October 22, 2026, 03:01:46 PM
Author Topic: simple macro not working,  (Read 10831 times)
« on: February 19, 2019, 12:05:55 PM »
I have made a simple macro for mach3 to move my z down by .0001 but this script does not seem to be working
I have named it M100.m1s I made it in text editor and vb script editor. but it does not seem to run, what am I doing wrong?
it does work when I run it in vb script editor but not when i run it from mdi
thnaks
jerry
code "g91"
code "g0 z-.0001"
'While IsMoving()
code "g90"
'Wend
Offline TPS
  •  2,627 2,627
Re: simple macro not working,
« Reply #1 on: February 20, 2019, 12:34:22 AM »
try this:
Code: [Select]
code "g91"
code "g0 z-.0001"
While IsMoving()
Wend
code "g90"
« Reply #2 on: February 20, 2019, 11:36:58 AM »
no that did not work.
 Is there any thing special  in saving the file format?
Offline TPS
  •  2,627 2,627
« Reply #3 on: February 20, 2019, 11:41:25 AM »
but it is in the right Folder?
C:\Mach3\macros\your profilename
any errormessage in the status line?
« Reply #4 on: February 20, 2019, 06:56:03 PM »
it is in the right folder and no error messages
Offline TPS
  •  2,627 2,627
« Reply #5 on: February 21, 2019, 12:15:50 AM »
ok i have tested here, and you are right.
for what ever reason M100 does not work, try M101.M1S
« Reply #6 on: February 21, 2019, 10:31:35 AM »
IT WORKS NOW.
Figures Id pick the one number that does not work.....
thanks so much
