Hello Guest it is November 13, 2026, 09:39:34 AM
Author Topic: Homing Script Gantry Squaring  (Read 9198 times)
« on: February 19, 2019, 08:33:45 AM »
Hey guys I recently overhauled an old MultiCAM router with a new controller and am using Mach3.  Everything is set up and running great but Im trying to solve an issue with my auto gantry squaring script while homing.
The issue is that currently X is set up with two steppers at each end of the gantry like a typical setup.  When I home X and A home together but only activate off the X switch.  Now I went into settings and there is no change if "Home Slave with Master" is selected or not.
However, when I go to Config->Slave Axis and unslave the A axis, restart Mach3, and run the same homing script again it works as intended and A will correct itself to it's own switch squaring the gantry.  I then have to re-slave and restart Mach3 again.
I'd like to not have to go through that process and it home without having to mess with the slave axis settings.
I feel like I'm missing something in my script (below).  I tried using CoupleSlave commands with no luck (shown in comments in script where).  Any help would be appreciated.  I have the feeling I need to enable independent A movement somehow.
Code: [Select]
' Ref all home Script
'Home Z
DoButton( 24 ) 'Z (4)
While IsMoving
Sleep(25)
Wend
DoOEMButton(135)
Sleep(500)
'Home Y
DoButton( 23 ) 'Y (2)
While IsMoving
Sleep(25)
Wend
Sleep(500)
DoOEMButton(134)
Sleep(500)
'Home X and A Together
RefCombination(9)
While IsMoving
Sleep(25)
Wend
Sleep(5000)
'Square Gantry Check
Message "Going into Square Check"
SquareCheck
Message "Done"
Sub SquareCheck()
If IsActive(XHome) Then
Message "X Active If 1"
If IsActive(AHome) Then
DoOEMButton(133)
Message "Gantry Already Square 1"
Exit Sub
End If
Message "X Home, Homing A"
DoOEMButton(357)
' I TRIED CoupleSlave(0) COMMAND HERE WITH NO SUCCESS
Sleep(500)
DoButton(25)
Message "Squared A"
DoOEMButton(358)
' ReCouple CoupleSlave(1)
DoOEMButton(133)
Sleep(500)
Exit Sub
End If
DoOEMButton(133)
Message "Gantry Already Square 2"
Exit Sub
End If
Message "A Home, Homing X"
DoOEMButton(357)
'CoupleSlave(0)
Sleep(500)
DoButton(22)
Message "Squared X"
DoOEMButton(358)
'CoupleSlave(1)
DoOEMButton(133)
Sleep(500)
Exit Sub
End If
Exit Sub
End Sub
Using an XHC USB Mach3 Motion Control Card Mk4 (link)
Re: Homing Script Gantry Squaring
« Reply #1 on: June 15, 2020, 11:09:21 AM »
Hi
I have xhc Mk4-ET motion controller. I have problem like you with homing gantry. did find the solution?
