Hello Guest it is November 12, 2026, 12:03:19 AM
Author Topic: Problem with Home/Limit Switches  (Read 30088 times)
« on: February 16, 2019, 03:52:21 PM »
Good day, I'm using Pokeys57cnc. However, for some unknown reason, I am not able to have mach3 recognizing the switches. I have connected on pin 18 on the axis switch connecteor for the x axis the switch, so that when it is hit, low potential is on. On mach 3 I had selected as home ref switch pin 18, didnt work (showed no reaction to the chaning of the potential). I then switched to external dedicated, didn't work either. I then tested the additional limit swichtes connections, same there on pin 11. I'm sure I'm missing out on something, but I cannot figure out what it is. I followed the manuals of pokeys, to no avail so far. Any guesses?
Re: Problem with Home/Limit Switches
« Reply #1 on: February 17, 2019, 01:53:42 AM »
Solved. Had to reset the PoKeys controller.
