Hello Guest it is October 23, 2026, 06:53:53 PM
Author Topic: SRO disable  (Read 5554 times)
SRO disable
« on: February 16, 2019, 04:58:33 AM »
Hi All,
I Need an M function to disable the SRO especially when taping ,Is this possible with mach4
Re: SRO disable
« Reply #1 on: February 16, 2019, 03:04:51 PM »
yes it is possible.
Look in the 'Spindle' category of the Mach AI.chm:
Code: [Select]
LUA Syntax:
rc = mc.mcSpindleSetOverride(
number mInst,
number percent)
Description:
Set the spindle override percentage.
You could use this or you might experiment with another from the same category:
Code: [Select]
LUA Syntax:
rc = mc.mcSpindleSetOverrideEnable(
number mInst,
number enable)
This API determines whether a SRO is applied at all.
