Hello Guest it is October 22, 2026, 04:50:16 PM
Author Topic: Mach3 and UC100  (Read 23521 times)
Re: Mach3 and UC100
« Reply #10 on: February 13, 2019, 11:03:34 AM »
You need to assign pin numbers for any pins you'll be using.
Offline Ray
  •  70 70
Re: Mach3 and UC100
« Reply #11 on: February 13, 2019, 12:50:11 PM »
I really appreciate your help Gerry.  I will see how it goes.  Thanks
Offline Ray
  •  70 70
Re: Mach3 and UC100
« Reply #12 on: February 15, 2019, 08:43:33 PM »
Gerry, I assigned pins and port 1, for X,Y,Z in Motor Configuration and enabled them.  I assume to get the steppers to move X,Y table and Z that I must also assign pins and possibly ports in either Mach3 Input or Output.  Do not know what to do after  X,Y,Z in Motor Configuration.  Please assist me.
Offline Ray
  •  70 70
Re: Mach3 and UC100
« Reply #13 on: February 15, 2019, 08:57:38 PM »
Is anyone using the UC100 with Mach3?
