Hello Guest it is November 13, 2026, 08:06:55 PM
Author Topic: Mach3 Breakout Board Inputs  (Read 14375 times)
« on: February 07, 2019, 07:15:28 AM »
I have a Mach3 PCI breakout board. Am trying to configure my limit switches to 3 of the 5 input pins available(10,11,12,13,15).
So my configuration is as follows:
X Axis Limit switch: port 1 pin 15
Y Axis Limit switch: port 1 pin 13
Z Axis Limit switch: port 1 pin 12
The x and y axis limit switches do trigger the interrupt on the software but the z axis does not. Have verified that the limit switch works fine. In fact when I put the z axis signal into the x axis pin, it does trigger the interrupt. I feel that there is some error in the port and pin configuration for the z axis. Any help in this regard is much appreciated.
Thank You
  •  9,377 9,377
Re: Mach3 Breakout Board Inputs
« Reply #1 on: February 07, 2019, 09:07:36 AM »
Can you give us some more details about this breakout board ?
Offline TPS
  •  2,627 2,627
« Reply #2 on: February 07, 2019, 09:38:48 AM »
have you tryed to connect to an other pin (10/11)?
« Reply #3 on: February 07, 2019, 11:55:29 PM »
Hi
PFA the link to the user manual for the board
https://warp9td.com/images/BOB_Vendors/StepperOnline/ST-V2.pdf
@TPS Yeah we did try that. the same problem for pins 10, 11, 12 but 13 and 15 work fine
  •  9,377 9,377
« Reply #4 on: February 08, 2019, 12:37:45 AM »
Do you have the 12 - 24V power supply connected to the breakout board ?
« Reply #5 on: February 08, 2019, 12:54:11 AM »
Yes
  •  9,377 9,377
« Reply #6 on: February 08, 2019, 01:09:17 AM »
Bin that breakout board and replace with one of better quality.
« Reply #7 on: February 08, 2019, 01:15:31 AM »
Would have done that, but tested 2 such boards out. Both have the same problem, which seems highly inconvenient
« Reply #8 on: February 08, 2019, 01:39:59 AM »
when I was still using Mach3 (now on Mach4) I used two breakout boards from Homann Designs in Auatrailia:
https://www.homanndesigns.com/index.php?main_page=product_info&cPath=54_22&products_id=59&zenid=d57t79b1cg7ac4l2676v12okd5
Of course I live in New Zealand so close to local for me. Been great. I still use them now that I have a Smoothstepper.
Really that's your choice....just get a breakout board and stick with a parallel port (and its limitations) or get yourself
an external motion controller like a SmoothStepper or a UC300 or similar.
DONT BUY CHINESE JUNK!
Cheap is about the only thing you'll like about them.....and really, are they that cheap when you have to throw them out
because they don't work?
