Hello Guest it is October 28, 2026, 08:42:31 AM
Author Topic: Paralell Port Setting  (Read 113673 times)
« on: February 02, 2019, 12:15:42 PM »
Where in Win7 do I find the 0x???? to input in the Ports and Pins settings. I have a pci add on card, it shows it in Device Manager, but dont see any number that looks like that.
Offline DMBGO
  •  201 201
  • Time is the same in a relative way
Re: Paralell Port Setting
« Reply #1 on: February 02, 2019, 01:56:07 PM »
0x is the start of the LPT port address that you add on card supports. Examples are as follows:
Address   Notes:
3BCh - 3BFh   Used for Parallel Ports which were incorporated on to Video Cards - Doesn't support ECP addresses
378h - 37Fh   Usual Address For LPT 1
278h - 27Fh   Usual Address For LPT 2
Click on the menu item "Config" then "ports and pins" You will see dialogue boxes for the port addresses, such as 0x378" for port #1. You need to set these to match you card.
David
  •  9,375 9,375
« Reply #2 on: February 03, 2019, 12:55:43 AM »
Look at the Properties for your PCI Card in Device Manager. Under Resources use the first address shown for I/O Range (ie. 0378) Mach will automatically add the 0x.
