Hello Guest it is November 22, 2026, 02:25:53 PM
Author Topic: Text In LCam 2.04  (Read 8412 times)
Text In LCam 2.04
« on: August 12, 2007, 12:19:17 AM »
Having problem with the Text feature in LC 2.04.  When LC writes the Gcode and I import into Mach3 the letters come out reversed when they are cut.  They show properly in the tool table window and the mill cuts them in the proper order, but the letters are upside down.  I have tried every configuration of port and pin reversals, etc.  Reversing the Y axis to Dir Active Low got the text to cut properly, but then the Machine Coordinates and the DRO coordinates will not synch.  Could be a machine problem, but I haven't had any problem with other code.
Any and all assistance and direction appreciated.
Bob @ BobsShop - Typing, twisting,and turning.
