Hello Guest it is November 13, 2026, 06:17:03 PM
Author Topic: where are the files kept?  (Read 7249 times)
« on: January 28, 2019, 01:21:21 PM »
Hello Chaps - I am using mach3 and in a moment of madness I have rearranged the files and folders into what I thought would
be a nice looking folder structure.
Now when I open up Mach3 doesnt know where to find all the pictures>
 could someone please tell me which folders must contain which files so that Mach3 knows where to look?
I will then rearrange everything and not go touching and fingerpoking again
 much appreciated
fred
think of the trees-- use both sides of the computer paper
  •  9,377 9,377
Re: where are the files kept?
« Reply #1 on: January 29, 2019, 12:20:41 AM »
From your Profile (bottom right of screen) the pictures are stored within a folder of that name which is inside your Bitmaps folder which is inside your Mach3 folder.
ie. If your Profile is Mach3Mill then all the relevant images are stored within the MillBitmaps folder which is in your Bitmaps folder which is within your Mach3 folder.
(re-installing Mach3 should re-arrange all the folders correctly).
