Hello Guest it is November 13, 2026, 03:03:01 PM
Author Topic: Mach3 Threading and Index Signal Problem  (Read 7922 times)
« on: January 27, 2019, 03:56:51 AM »
Someone knows this card
nvum v2 3 axis.
I can not make the thread because mach3 is waiting for the index pulse.
if I connect index to input as per manual, read the rpm correctly but without the index lamp lights up.
Instead if I connect index  to  another input(like proximity switch) , the index light turns on but does not read the rpm and if I try to do threading, mach3 remains waiting for the thread signal…..
« Last Edit: December 11, 2019, 05:21:19 AM by Tweakie.CNC »
  •  9,377 9,377
Re: Mach3 Threading and Index Signal Problem
« Reply #1 on: January 27, 2019, 05:22:05 AM »
I have sent you a PM.
« Last Edit: January 27, 2019, 05:25:25 AM by Tweakie.CNC »
