Hello Guest it is November 22, 2026, 02:30:07 PM
Author Topic: digitize input to turn on an output Mach3  (Read 29615 times)
« on: January 18, 2019, 08:28:19 PM »
I am tired of having to look at the diagnostics screen to see if I have probe continuity before running auto zero. I did modify the screen to add a digitize led by the auto tool zero button. Still would like a LED at the router so I don't have to look at the computer at all. How would I configure the probe input to turn on an output that I could drive the LED with.
Offline TPS
  •  2,627 2,627
Re: digitize input to turn on an output Mach3
« Reply #1 on: January 19, 2019, 02:22:24 AM »
you can not configurate this.
you have to use a brain, or macropump for this.
« Reply #2 on: January 19, 2019, 09:21:43 AM »
I was afraid there would be no easy way to do this. I even thought that some simple circuitry that's watching the input circuit could turn on the led but I'm not savvy enough to come up with that.
Offline TPS
  •  2,627 2,627
« Reply #3 on: January 19, 2019, 10:49:15 AM »
ok, no Problem.
give me the Output number you want to turn on, and i give you the brain,
and the instruction, how to implenet it.
« Reply #4 on: January 19, 2019, 11:53:57 AM »
I am using Port 2, Pin 11 for my probe input and would like to use Output 4 to drive the LED. Would there be much delay from contact to the LED coming on. I am using a PMDX-126 with USB smoothstepper. Thanks for your help.
Offline TPS
  •  2,627 2,627
« Reply #5 on: January 20, 2019, 02:40:56 AM »
ok,
attached the brain.
-copy the file to c:\mach3\brains
-start Mach3
-goto Operator -> Brain Control
-highlite the brain DigitzeLED.brn
-set the enable hook
-press reload all
finished
then you can Switch to the diagnostic sceen, and watch output4
« Reply #6 on: January 20, 2019, 10:11:42 AM »
While waiting for your file I decided to delve into brains myself. I had some Boolean logic from school and the only difference between
yours and mine was you used a pass through and I used an immediate compare > 0. They both work fine. Thanks for inspiring me to
learn. 40 below C hear last night. Hope your in better weather.
Offline TPS
  •  2,627 2,627
« Reply #7 on: January 20, 2019, 11:18:23 AM »
nice to hear, you got it working.
btw it is a bit wormer here, but also -5°C.
« Reply #8 on: July 18, 2021, 06:33:59 PM »
Another... More simpler solution that I use, is to take an LED light from a flashlight or something, take the power source, (usually 3xAAA batteries) mount it somewhere convenient, and with a couple alligator clips, attach one end to the tool, and one to the material. Lower tool slowly until it makes contact, it will light up until you retract. Might be a lil Jimmy rigged, but it's useful and no programming necessary. I also use it for setting height and depth on my table saw and radial arm saw. Hope this was helpful.
