Hello Guest it is October 24, 2026, 06:23:34 PM
Author Topic: How to copy all the profile settings, ini, plugin cfg, screens to new computer?  (Read 6403 times)
I have setup a Mach 4 profile with everything the way I want on old computer but now want to move that profile to a new computer that has a new license and deactivate the license the old computer. I want to be able to deactivate using the Mach4 License Manager from one to the other when needed. Basically, to be used as a backup system in case something goes wrong.
I can get everything to work except the Reference All Home, which just zeros out DROs where ever spindle is located. I also have a custom screen created that Bryanna suggested in on of her videos. PMDX works, Configuration looks the same on Home/Soft Limits, etc.
Not sure of the correct steps to do this and most of the references I have found refer to copying from Mach 3 to Mach4.
Any help appreciated.
Bryanna answered my question on another post.
This can be closed/deleted/ignored.
Offline thosj
  •  542 542
I think you could just leave two licenses ACTIVE, no problem.
Tom
