Hello Guest it is November 13, 2026, 09:40:39 AM
Author Topic: Mach 3 Z-axis brake control by mach 3 estop  (Read 8038 times)
« on: January 08, 2019, 05:04:27 PM »
Hello, I am running a cnc router that has a brake on the z axis.  I would like the brake (24v relay controlled) to disengage when the mach 3 estop (the soft version, not the machine hardware estop) is cleared.  Is there a way within Mach 3 to setup a linkage between the estop and an output on my controller?  Running the CSLabs CSMIO/IP-A controller.  Basically, when I clear the estop within Mach, i want my output to fire which would disengage the brake.  Sorry if I am missing a clear function that can do this.  Thanks!
Offline TPS
  •  2,627 2,627
Re: Mach 3 Z-axis brake control by mach 3 estop
« Reply #1 on: January 09, 2019, 01:40:59 AM »
Config -> Ports&Pins -> Outputs -> Enable1 to Enable6 should work.
