Hello Guest it is November 13, 2026, 03:16:27 PM
Author Topic: Motor Tuning doesnt Open up in mach3  (Read 14152 times)
« on: January 03, 2019, 02:58:15 PM »
Does anyone know why all the settings work and open up
But
Motor Tuning will not open up the dialougue box?
All other settings open up
Im using Windows 10 64 bit with version R3.043.066
and the BOB is a NVUMC Version 2? :)
  •  9,377 9,377
Re: Motor Tuning doesnt Open up in mach3
« Reply #1 on: January 04, 2019, 12:13:52 AM »
In October you posted "I just tuned motors for the first time with my Windows 10 64 bIT PC Using mach 3 and its working 100%".
What have you changed in your setup to cause the problem ?
« Reply #2 on: January 04, 2019, 02:59:56 AM »
Thanks for replying
I dont think anything has been changed!
I used to have the v1 version of the BOB but now have the V2 buhink the v2 was installed so no other thing has been changed!
It just fails to open up Motor Tuning and all other items work in the mach 3
My motors were Axis Calibirated set steps per unit okay in MM
But now my Nema 23s move very slowly, so i was thinking i now have to beef up the speed in them??
But tried via the motor tuning but it doesbt open up?
Ive restarted the PC and also the System still doesnt work!
Does anyone know why this Motor Tuning doesnt open up???
  •  9,377 9,377
« Reply #3 on: January 04, 2019, 04:22:53 AM »
If you have changed your BOB (motion controller) then you need to delete the old and re-install the correct drivers (plugin software supplied by nv for that model BOB).
« Reply #4 on: January 04, 2019, 06:55:19 AM »
Hi
No the <a href="http://driver is the correct one" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://driver is the correct one</a> and was working okay before!
and just reinstalled it
Though i noticed it was plugged into a RED Usb Socket and have since plugged back into a USB 3 blue port!
https://youtu.be/jU6MA85nJgU
does anyone else know why its not working?????????
  •  9,377 9,377
« Reply #5 on: January 04, 2019, 07:13:34 AM »
I have sent you a PM.
